Any update on the 034MOTORSPORT chip?
i emailed them a few days ago, alas, no answer.
Yep, it's going well now that the car we have here is sorted.
Came in with a severely slipping clutch, so not much could be done until that was sorted.
Got the car on the dyno last night and started getting the AFR's more dialed in (stock trends were a bit less than ideal). Ran out of time before we could get a lot more done, should have some more results Monday when we're back at it. |
great keep it up!
i believe my stock clutch is also starting to slip some as well notice it most in 4th gear going up hills just seems to start to lose power but not all the time..
in
Loss of power doesn't equal clutch going out, unless your revs are climbing and the car's slowing...
What are the specs of the car you have?
Stock for the most part, some intake mods goin on for a 1+ chipset
Came in with a stock MAF/intake setup, fairly stock exhaust, replaced the rear with a Magnaflow muffler, still on dual stock sized cats.
We'll be doing a tune for both the stock MAF and a de-shrouded big bore setup. |
i emailed your company about stand alone ems and the chip, and your coworkers seemed to not be aware
of a chip for the 12v,...i need a solution to heavily modified 12v engines, whether it be ems or a reflash, which ever my be cheaper....
Technically, there still isn't a 12v chip available.
This program is just getting started and in it's development/testing phases.
As for a chip fitting your needs, that all depends on what mods, and what you're looking for. |
