Power Steering Pump and Pulley replacement
My son just bought a 1995 90 Quattro for $1300. The car is in nice shape with no damage and 98k miles. Tranny and engine are strong. The seller informed him that the power steering pump was bad.
We ordered the pump for him and upon inspecting the car, we discovered that the pulley is missing and all the lines had been removed from the old pump.
This may be a stupid question, but what will I need to do the job (as far as the pulley replacement goes) and does anyone know where I can find a pulley and all that is needed for the installation?
So, after receiving the wrong pump TWICE, I think we are getting the correct pump tomorrow. I also managed to locate a pulley, however, I still need the bolts to connect it and am still wondering if there is any special gaskets/seals/tools that I will need to complete the job. The old pump is off and it was a pretty easy job...will the installation of the new one and pulley be as easy?
Please help! My head hurts from all the internet searches!
Rule of thumb is that anything easy to remove is easy to put back on. Bolts should be easy too as long as you find a sample bolt that works, and get some more at the hardware store. Assuming that you have the hoses to hook up to the pump, you'll also need power steering fluid. If that steering rack has been running dry for a long time, don't be surprised if it leaks. If the steering system is completely empty, you might just fill with Prestone power steering fluid with stop-leak, instead of the expensive Pentosin. Don't run the pump unless you have purged air from the system first, or the replacement pump may be damaged.
1 Post
Both fittings usually require a 22mm socket.
Thank goodness for cardone.com!! The power steering pump came in and it was nice to see that it was the correct one. The fun of replacing it, flushing the system and praying nothing leaks begins tomorrow.
Thanks for the info.
Don't be surprised if I'm back to ask more stupid questions at a later date.
technicoloraudio
A4 (B7 Platform) Discussion
08-19-2018 10:26 PM
NinetyQ
02-04-2013 04:25 PM
