question
i think just the speed sensor. should be on the drivers side, behind the ac compressor and under the bracket for the engine mount. you have to remove the sensor to install the crank holding pin.
on the drivers side of the engine, there are 2 sensors, one is cran possition sensor (thats the one that bolts in to the block, and the 2nd one is for RPM, it reeds of the teeth from your flywheel
Jim Castronova
04-13-2018 03:43 AM
