will the 12v handle nitros
no it wont.
if you build it, it will, stock, it will not. these are high compression engines
Originally Posted by CRAZY_RUSSIAN
(Post 24408704)
You could probably get away with a small <50 shot stock if your AFR is correct. To go higher you need aftermarket pistons, MLS head gaskets, and ARP head studs. You could probably spray a 200 shot with the correct timing and AFR. I would feel a lot safer with aftermarket rods too, but the stockers would probably live if tuning was spot on. |
yeah, good point, but with our stock tune and tiered old engines and him having to ask, i would not recommend this. there are other upgrades he can do that are cheaper and give you a batter and CONSTANT source of power
speaking of MLS head gaskets.... where can u find one for our cars? im running ARP studs but standard h.g.
