2.0 TFSI random misfire
I have a 2010 A4 Allroad 2.0 TFSI with 120 000km on the clock. About 3-4000km back I changed oil, filter, sparkplugs and coils.
But before that the car would suddenly hesitate and start shivering (misfireing, limp mode?), this only happend 2-3 times during about 6 months and would only last for a short while (like 5-15 seconds) then clear up by itself. Can't remember if the CEL light ever came on either.. maybe once but I never got any fault codes. This led me to put new coils in when I changed the plugs (plugs where due for the 120 000km service). But a couple of weeks ago it happened again, only this time it didn't go away until the engine had cooled down. I drove it gently for maybe 10-15km like this just to get back home. This time the CEL light came on and stuck on, ESP light also came on. So I plugged in my bluetooth OBDII reader and checked for codes in the Torque app on the phone. Only code I had was misfire on cyl 4. So while the engine was cooling off I swapped the coils on cyl 3 and 4, it took a lot longer than usual on the starter before it powered up but once the car started the engine ran nice again. So I took it for a testspin with the phone app logging everything it could and when I got back I didn't have any new faultcodes. But I found a value called "EWMA misfire count" in the log that stated that I'd had a number of misfires on cyl 4. But the car still ran good, and I didn't get any fault codes.. About a week later it once again started shivering, but corrected itself after maybe 10 seconds.. no fault code. Of all the times this has happened, it's never happened directly after a cold start. Twice it has happened with the engine truly at operating temperature. And all the other times after maybe 4-6km of driving from cold start so more or less warm. The only thing I've noticed is that the fuel consumption is a bit higher than what I would expect, but then I've got 255's on it so that might be the cause there.. :) From what I've read the most common culprits for this issue are in decendeing order: Coils Plugs Vacuum leak Injector MAF Carbon build up Out of these the first two should be the problem. The last one should cause problems during cold start before problems accure when warm? An injector feels far fetched.. Is it really common for these to fail after only 120 000km? Vacum leak is possible, are there any common vacum lines that are prone to crack on these that I should start by checking? And with the MAF, if that's the issue It should be all the time, shouldn't it? Since the issue is so random and won't leave fault codes (atleast none that I can read, are there any VAG com stuff for DIY mechanics that read more info than other?) I'm not very keen on sending it to an Audi workshop.. Atleast not yet. Does anyone else recognize these symptoms? Have I missed something ion my list that could be the issue? Or should I first get a better OBDII reader? If so, which one? Is Ross Tech still the best one out there for DIY'ers? |
Problem
Got similar issue. Did you ever figure it out?
Originally Posted by Jmonsiv1
(Post 25370818)
I swaped all four injectors (thou one should have been enough) and the problem went away at the same time as the fuel consumtion went down a notch :) (From 0,8 litres per 10km down to 0,75 l per 10 km on the highway) |
Reply:
Originally Posted by Cassius
(Post 25372009)
Yes I did!
I swaped all four injectors (thou one should have been enough) and the problem went away at the same time as the fuel consumtion went down a notch :) (From 0,8 litres per 10km down to 0,75 l per 10 km on the highway) Best of luck |
Originally Posted by Cassandra Castle
(Post 25376622)
Hello, first time replying on here. I was having problems also at idol speeds and idol after starting. I would if you run in to this again check the PVC valve diaphragm. It could have a RIP which can cause these issues along with misfires. You can change out the whole pvc valve and hoses or as quick fix pvc valve diaphragm, which I did for now. Just make sure you know how it was positioned so new one goes on correctly.
Best of luck |
(Post 25376769)
From what I have read, the PCV valve issue is more "permanent", and usually when cold and then goes away as the engine gets warmer? For me it was very sporadic (4-5 times during a period of 6 months), never from cold only when warm or half warm. So the fault didn't really match a broken PCV valve.. :)
Same issue here. I did the following, still is an issue
4 plugs 4 coils new turbo new N75 new DV new PCV (Oil separator) Cant find any vac leaks even tried to install a test pipe thinking perhaps the cat was really clogged In the process of doing a de-carbon this weekend, but I don't think this will fix it either as they were not super bad. Im lost |
