are these codes to worry about?
Address 01: Engine Labels: 06F-907-115-AXX.LBL
Part No SW: 8P0 907 115 B HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0070
Coding: 0103010A1C070160
Shop #: WSC 09401
5 Faults Found:
012599 - Intake Manifold Runner Control: Basic Setting not Completed
P3137 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Mileage: 28191 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 56.0°C
Temperature: 51.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.065 V
001602 - Sensor Reference Voltage A: Circuit: Low
P0642 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 28191 km
Time Indication: 0
Freeze Frame:
RPM: 177 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 54.0°C
Temperature: 54.0°C
Voltage: 10.541 V
008196 - Intake Manifold Flap; Bank 1: Stuck Open
P2004 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 2
Mileage: 28193 km
Time Indication: 0
Date: 2007.07.06
Time: 15:58:24
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 38.0°C
Voltage: 12.827 V
012403 - Fuel Pump Circuit: Electrical Malfunction
P3073 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 28294 km
Time Indication: 0
Date: 2007.07.10
Time: 19:01:32
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 48.0°C
Voltage: 12.700 V
012600 - Intake Manifold Runner Control: Regulation Deviation
P3138 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 28375 km
Time Indication: 0
Freeze Frame:
RPM: 1373 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 50.0°C
Temperature: 47.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
Readiness: 0000 0000
Shop #: WSC 09401
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 28191 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 56.0°C
Temperature: 51.0°C
Voltage: 12.065 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 28191 km
Time Indication: 0
Freeze Frame:
RPM: 177 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 54.0°C
Temperature: 54.0°C
Voltage: 10.541 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 28193 km
Time Indication: 0
Date: 2007.07.06
Time: 15:58:24
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 38.0°C
Voltage: 12.827 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 28294 km
Time Indication: 0
Date: 2007.07.10
Time: 19:01:32
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 48.0°C
Voltage: 12.700 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 28375 km
Time Indication: 0
Freeze Frame:
RPM: 1373 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 50.0°C
Temperature: 47.0°C
Voltage: 11.938 V
Re: are these codes to worry about?
i got the same thing going with mine. I brought in twice already this is my third time. I told them to keep it untill they fix it. Bringing it in Wed.
GTI 2.0t
GTI 2.0t
