01 s4 boost issue
01 s4 boost issue
hey guys im new here and im trying to figure out why the heck is my car not boosting?
Symthoms? : check engine says maf high input...
its a tiptronic and the car drives nice,it doesnt hesitate nor idles rough,it doesnt miss,but as you go down the road the car feels very slow as in if i was to floor it the car will downshift and has a very hard time reving up,i feel its sucking alot of air but the car wont put my head in the head rest! but when the ESP & ABS light turns on at the same time the car will go a bit faster!ive changed wastegate actuator (boost valve n75) but the car hasnt changed a bit,i highly doubt its the MAF sensor...i have a mac mentor scanner and i clear the code everytime the CEL comes on,but thats the only code and i have no idea why im stuck on limp mode then the ESP and ABS light pops on the car boost a little more? shouldnt it be the other way arround?also when i disconnect the MAF the car feels worst.
Bad MAF, or a big intake leak, or a boost pipe blew off. Air filter isnt clogged, or the snow screen inside of the airbox assembly can get plugged solid and starve the engine of air bigtime.
When the ESP and ABS lights come on at the same time, that's a dead giveaway that the brake light switch is toast. I've had to replace 2 of them and each time the symptoms are low boost levels and the two dash lights. $20 part and 10 minutes to replace.
how is it that i could have a toasted break switch if my lights DO work when pedal is pressed?
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-09-2015 12:00 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-09-2015 11:51 AM
ECS Tuning-Audi
09-08-2015 01:08 PM
ECS Tuning-Audi
09-08-2015 11:47 AM
S4intheOC
09-08-2015 12:12 AM
