2.7T Allroad check engine light problems
I have a 2001 Allroad with 2.7T and auto..
I am getting the following codes
P0171
P0172
P0174
P0175
I changed Bank 1 Pass. Ox sensor and I still get the codes after 20 miles of driving no matter if on the highway or around town
any ideas?? I check for vacuum leaks and replaced a line that looked weak
P0171
P0172
P0174
P0175
Link inside should help
P0171 - you're running lean
P0172 - you're running lean
P0174 - you're running rich
P0175 - you're running rich
did you plug the O2 sensor back in? maybe all of them are bad? have you pressure tested? you don't have a bad EGT, yet... Maybe a bad MAF is causing the codes to get thrown.
Please, find someone with a VAGCOM to do a real scan and post it up.<ul><li><a href="http://www.s4biturbo.com/dtc_search.cgi">P-code search</a></li></ul>
System too lean and too rich banks 1 and 2
You may have an intake leak, that will cause to lean at idle and two rich during boost. If you don't have a leak and you have a bosch MAF sensor then replaced the MAF. I highly doubt it is you O2 sensors.
UseTheS4ce
12
04-27-2005 09:21 AM
::Relapse::
07-21-2004 12:51 PM
can anyone advise DTC Codes 17538 & 17536 ? Any experience with these? Should be MAF sensor failure.
Mike S
9
06-21-2001 06:55 AM
Another Drew
05-21-2001 10:46 AM
