Audi A6 2.7t tiptronic - radiator troubles
Hi
I own an 1999 A6 2.7t that needs a new radiator - easy you'd think -
however the part supplied turns out to be smaller, or actually shorter
than the original part and so does not fit properly between the luggs
and the feet. I have so far tried three different radiators from three
different sources - none of which fit! The problem seems to be that
the radiator needs to be specific to the auto model as it houses a
connection to the oil cooler for the auto gearbox. I have even
contacted AUDI and the part no that they quoted is the same as the
part i have already tried that does not fit i.e. it's too shallow -
shorter than the original part. In fact in my search so far I have
been supplied with two different parts: one appeared to be for the
maunal transmission model as it did not have the oil cooler attachment
for the auto gearbox, but was however the right height to fit; the
other part did have the right connections for the oil cooler, but was
too shallow (too short) and would not fit!! AUDI's computer system
does not mention any fitting kit or any amendments to the design of
the part so it should be the same dimensions as the original part, but
it's not!! I'm at a loss for ideas and can't believe this is possible
- also, my car has now been off the road for three weeks! Can anyone
out help, or have any of your come across the same problem?
Cheers
Rob
Cheers
Rob
Robb06
05-14-2007 11:27 AM
A6intel
01-24-2002 08:43 PM
