Audi Allroad running rough, misfiring. Pulled VCDS Codes
Been having an issue for almost 2 weeks now.
Still trying to find the answer.
Car SUDDENLY started running rough. at idle and during acceleration. Misfires randomly. Little backfires.(pops)
What I've done:
Pulled and cleaned MAF.
Unplugged MAF, didn't seem like much of a difference.
I disconnected the battery a couple of times.
Found a cracked Vacuum line on Pass. side PCV. fixed.
Tried cleaning up gas.
Checked air filter.
It has moments and if I'm at about 3000 rpm and not accelerating it runs almost normally.
I'm (right now) guessing MAF?
Ordered a cable and loaded up VCDS Lite. Here's the codes I pulled:
Address 01: Engine Labels: 078-907-551-AZA.LBL
Controller: 4Z7 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02136
VCID: 4DEDEA3794C9
WAUYP54B11N156251 AUZ7Z0A1828266
12 Faults Found:
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
17978 - Shareware Version. To Decode all DTCs
P1570 - 35-10 - Please Register/Activate - Intermittent
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-00 - Please Register/Activate
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
17521 - Shareware Version. To Decode all DTCs
P1113 - 35-10 - Please Register/Activate - Intermittent
17887 - Shareware Version. To Decode all DTCs
P1479 - 35-00 - Please Register/Activate
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16685 - Shareware Version. To Decode all DTCs
P0301 - 35-10 - Please Register/Activate - Intermittent
16689 - Shareware Version. To Decode all DTCs
P0305 - 35-10 - Please Register/Activate - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
18010 - Shareware Version. To Decode all DTCs
P1602 - 35-10 - Please Register/Activate - Intermittent
16815 - Shareware Version. To Decode all DTCs
P0431 - 35-00 - Please Register/Activate
Readiness: 0000 0001
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 4Z7 927 156 A
Component: AG5 01V 2.7l5VT USA 1718
Coding: 00002
Shop #: WSC 00000
VCID: 44FBCF134783
3 Faults Found:
18147 - Tiptronic Up Switch (F189): Short to Ground
P1739 - 35-10 - - - Intermittent
18152 - Shareware Version. To Decode all DTCs
P1744 - 35-10 - Please Register/Activate - Intermittent
18265 - Shareware Version. To Decode all DTCs
P1857 - 35-10 - Please Register/Activate - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Controller: 4Z7 907 389
Component: ABS/ESP allrad D57
Coding: 06397
Shop #: WSC 01234
VCID: 09651E272021
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
What I've done:
Checked air filter.
Coding: 06752
Shop #: WSC 02136
VCID: 4DEDEA3794C9
12 Faults Found:
P0304 - 35-00 - -
Coding: 00002
Shop #: WSC 00000
VCID: 44FBCF134783
3 Faults Found:
Coding: 06397
Shop #: WSC 01234
VCID: 09651E272021
1 Fault Found:
Felk_2.7T
12-03-2005 11:39 AM
the senator
16
07-09-2003 01:35 AM
