broken timing chain
broken timing chain
I had my timing chain rebuild service done at 73,000 mikes by local Audi independent . Last week at 84,000 miles a bolt on one of the tensioners for the chain broke, all hell broke loose. Pulled over asap was going 75 mph when it broke. I have always changed oil and done all service before it was needed and been meticulous on service. It was suggested by a 20+ year Mercedes mechanic who worked on Audis for over 15 years before his shop stopped working on Audis that the bolt may have been over torked during the timing belt service causing the failure. Thoughts? Thanks!
Are you positive that it was the bolt that broke? If it was over torqued I would think that it would have happened sooner than that. Could be that the belt was faulty or that the tensioner itself failed. What exactly happened (anything out of your ordinary driving I should say)? Or could the belt have been installed incorrectly?
Broken timing chain
2.7 broken timing chain
Left the car with my local independent who worked on it in between other work so it took a while. All the valves were bent and pistons damaged as well as the head. The mechanic replaced all the vales redid the head and rebuilt the whole top end of the motor. He had a way of doing this with out pulling the motor or transmission. We inspected the turbos and they were fine so we left them alone. Every thing damaged or worn was replaced and I got the car back in December and have been driving it since. It runs great and I have put over 5,000 miles on it since getting it back. Happy I fixed it.
90sportin
Audi Original "S" Cars
9
03-03-2005 09:33 AM
