Cam Position Sensor?
Could a bad Cam Position Sensor cause numerous other codes, such as, O2 sensor, MAF sensor codes to pop up? This is in regards to the bank #2 cam sensor on the driver's side.
I have taken it off, cleaned it and replaced, but it keeps coming back. I'm ready to put a new one in, but if there are some other things that I should check first, then I would rather do that.
t first, the only thing that seemed to be affected by the cam sensor problem was that at idle, the engine would seem to "hick-up" like it was resetting itself. This would happen within 1 second, and repeat every 5-10 seconds. When driving the car, everything seemed fine. Now, I have felt the car kind of shutter abruptly while driving, as if it was shifting hard.
Will Merritt
Q5/SQ5 MKI (8R) Discussion
09-13-2022 04:08 PM
Jason Sowers(rs6's)
06-13-2008 10:18 AM
