Cheers to the 2.7T forum. Let's be careful out there...
<center><img src="http://im1.shutterfly.com/procserv/47b4dd08b3127ccebb2d5a5e7d560000001610"></center><p>
Believe it or not, neither. Final cause was never determined with 100% accuracy but best bet shows
oil pump over pressure and valve float followed by crunch. Water pump, timing belt, tensioner all looked fine. No damage to turbos. No FOD in ics. It was a very strange occurence, indeed.
The oilpump over pressure problem was supposed to be corrected on the 2.7t with an internal pressure release valve integrated into the oil pump. Although the valve tested properly outside the vehicle, it 'could' have failed in one cycle and not the next.
I've had discussions with about every known 2.7t 'expert' in this country and even talked to cosworth. No one has seen this occure before. Occurred not long after startup at around 2600-2700 rpm.
GruvenS4
08-11-2004 10:07 AM
OCDaudi90q
07-21-2004 07:33 AM
Audi_Never_Follow
Audi 100 / A6 (C4 Platform)
9
04-22-2003 06:12 PM
StormChaser404
10-28-2002 05:14 PM
