AudiWorld Forums
AudiWorld Forums (https://www.audiworld.com/forums/)
-   2.7T V6 Discussion (https://www.audiworld.com/forums/2-7t-v6-discussion-107/)
-   -   Coolant Warning; No CEL codes (https://www.audiworld.com/forums/2-7t-v6-discussion-107/coolant-warning%3B-no-cel-codes-2914020/)
auditna 02-06-2017 01:01 PM
I'm getting the big red coolant warning screen as soon as I start my car.
1. No CEL and no codes from vag-com
2. Coolant level is perfect, no coolant is leaking as far as I can tell
What are some other possible causes besides the obvious (e.g., stuff I learned from searching)?
I've ordered an ECT sensor just in case I need to replace that, but I would have expected that to throw a code.
auditna 02-13-2017 08:39 AM
New sensor did not fix it. What else could be happening?
ConfusedSkunk 02-15-2017 07:54 AM
Could it be the wires to the sensor or any other coolant temp sensors?
I know when I was doing work on my car a while back I unhooked the sensor on the overflow and forgot to plug it back in. When I started it up, it didn't throw a code but just flash the same message.
auditna 06-17-2017 06:45 AM
Solved: make sure the coolant cap is screwed on all the way tightly. I was refilling coolant and I must not have tightened it all the way.
