Cranks and cranks but it will not start..
Its a 2000 S4 with 124k miles. Was in a collision which damaged the passenger front door, passenger bolster airbag and side curtain. Original ECU has REVO software and thought maybe it was a problem with that so I got another A-Box with GIAC X software with no results. Car will just crank and crank but while cranking everything will get a power loss and then continue to crank till it does it again. Here are the codes that I got from a scan.
VAG-COM Version: Release 311.2-N
WSC 02756 790 00000
Control Module Part Number: 8D0 907 551 A
Component and/or Version: 2.7l V6/5VT G02 0003
Software Coding: 06611
Work Shop Code: WSC 06325
2 Faults Found:
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
WSC 02756 790 00000
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 551 A
Component: 2.7l V6/5VT G02 0003
Coding: 06611
Shop #: WSC 06325
2 Faults Found:
Readiness: 0110 0101
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D56
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 980 DX
Component: B5-KOMBIINSTR. VDO D07
Coding: 02262
Shop #: WSC 00000
1 Fault Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to B+ - Intermittent
Address 35 -------------------------------------------------------
Controller:
Note: Can't Synch Baud Rate
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06325
4 Faults Found:
01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
35-00 - -
01381 - Alarm triggered by Anti-Theft Sensor: Rear Right
35-00 - -
01382 - Alarm triggered by Anti-Theft Sensor: Front Left
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor: Front Right
35-00 - -
Address 56 -------------------------------------------------------
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00115
Shop #: WSC 06325
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------------
I checked the engine speed sensor which is above where the driver side axle goes into the tranny and it wasnt disconnected or anything.
I also ran an output test and it came up with injectors 1-6 short to ground. Not really sure what the output test does. Any help as to where I should start looking?
Thanks!
WSC 02756 790 00000
2 Faults Found:
WSC 02756 790 00000
Coding: 06611
Shop #: WSC 06325
2 Faults Found:
Coding: 02262
Shop #: WSC 00000
1 Fault Found:
Controller:
Coding: 00101
Shop #: WSC 06325
4 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00115
Shop #: WSC 06325
1 Fault Found:
Thanks!
if all 6 of your injectors are shorted to ground, then something isn't plugged in somewhere, like
the ECU isn't seated in all the way or something.
also, might want to check the pin on the flywheels and double check your engine speed sensors for resistance.
