Fault Codes Due to Aftermarket DV??????
The 2 fault codes I am getting are:
Address 01: Engine
Controller: 4Z7 907 551 K
17539-Oxygen (Lambda) Sensor, B2 S1: Internal Resistance too high-P1131-35-10- Intermittent
17521-Oxygen (Lambda) Sensor, B1 S1: Internal Resistance too high-P1131-35-10- Intermittent
Readiness: 0010 0000
The check engine light has come on and then gone out on its own three times, and even after resetting and clearing with Vagcom, the CEL is still coming back on. Brought car to the dealer thinking they would replace O2 sensors on extended warranty, but they say the codeds are likley due to my aftermarket Forge diverter valves. Does this make any sense or are they just trying to avoid the O2 replacement???
Address 01: Engine
Re: 2nd, the DVs have nothing to do with the internal resistance of an O2 sensor.
If the DVs where bad, it would show a fault for recirc. valve. You want to see what the activity is registering on the O2 sensors.
310ALLROADER
VAG-COM Discussion
09-11-2005 06:13 PM
310ALLROADER
Audi allroad
12
09-10-2005 10:06 AM
audi1996
Audi 100 / A6 (C4 Platform)
07-25-2005 06:22 PM
stooby
04-13-2004 07:18 PM
