Faulty Oil Pressure Sender
Old 02-19-2008, 10:04 PM
Jonathant25's Avatar
Default Faulty Oil Pressure Sender
So, I've searched and searched both online (using the forum search) here and under my car and cannot find the location of the OPS. I've seen the S4 study guide, but cannot find the unit under the car. Based upon what I've read, I pretty sure mine has failed and if I hear the intermitent beeps anymore, I might drive my car into a wall!!! Help. Does anyone with experience have any tips on finding this? I'm pretty mechanically inclined and can perform my own work, but feel rather silly being sidelined by this simple piece. Any help or pics would be much appreciated.
Thanks
Old 02-20-2008, 05:58 AM
quickaudi:STFA's Avatar
Default found this by searching for "oil pressure sender" in the B5 S4 forum, was the 4th hit
<ul><li><a href="https://forums.audiworld.com/s4/msgs/2525820.phtml">STFA FTW.</a></li></ul>
Old 02-20-2008, 05:11 PM
New Member
vwtech121's Avatar
Default Re: Faulty Oil Pressure Sender
the OPS is on the oil filter housing. you may have to drop the sway bar down to get you hand in there. I havn't seen many fail, I have seen loose connections at the sensor cause the light to come on from time to time. If you still have problem drop me an e-mail with your info and ill send you the tech bulletin from audi ( i think there is one for that) to check the connector.
-Don-
vwtech121@yahoo.com
Juxhinriza
01-06-2018 03:32 PM
HZ60
Q5/SQ5 MKI (8R) Discussion
11
05-04-2013 04:48 PM
roomabuzzy
01-28-2009 07:26 PM
Avant Sport
02-18-2007 06:14 PM
TCP
04-07-2002 03:50 AM
Quick Reply: Faulty Oil Pressure Sender
