First techincal question.
What Garrett gt series turbo will be the closest match for a 2.7T. Looking at the 490 - 590 HP range.
would like to run 19~24 psi.
HP graphs that look like an EXP function are of no interest.
I know k04/k16's peeps are in this teritory. I am wondering what a gt based turbo will yeild.
High timing advance and low AIT's wil make power, since i plan to keep boost down. Keeping the Stock C.R.
the goal is drivability, and smoothness. ( any car with ~500 Hp will feel violent enough, when combined with low gearing. )
I am thinking the gt 25 series from garret, with a .60 AR. worried this turbo will be way too large. ( might not be matched to the application goals )
Oil lines, and coolant will probably be a major headache. downpipes, will be a job from Hell. and manifold jiging will be beyond complicated.
Oulet, and inlet pipes are not to bad.
would it be wise to tackle such a project?
or! settle for k04s or K16 hybs. and play with tuning, on a standalone.
gt25 r is 750.
thats 1500 for two of them. and ~600 for manifold modifications.
" lots of places in detriot to weld up some pipes "
Garrett GT25R Turbo
$750 USD shipped in Canada or USA
Dual ball bearing
Internal wastegate
5 bolt discharge
Flow capacity of about 250hp
Turbine:
Wheel: 53mm w/ 62 trim
Housing: .64 ar
Compressor:
Wheel: 54.3mm w/ 60 trim
Housing: .80 ar
figure 200 for Oil and colant line modifications.
and 400 for modifying a set of DP's.
another 300 for intake and outlet plumbing.
~3k for the system.
or pay ~ 3 k for k16's?
gt25 r is 750.
Garrett GT25R Turbo
Dual ball bearing
Internal wastegate
5 bolt discharge
Turbine:
Housing: .64 ar
Compressor:
Housing: .80 ar
~3k for the system.
popdemonic
Audi Original "S" Cars
12-12-2008 08:27 PM
Milpitas2.7T
14
10-09-2006 09:59 AM
AndrewsQuattros
12
03-31-2002 05:12 PM
Lucas_Gchips
Performance and Tuning
12-04-2000 08:17 PM
