Headlight, turning signal, wiper, heat/air, brake lights and tail lights don’t work
Headlight, turning signal, wiper, heat/air, brake lights and tail lights don’t work in my2002 Audi A6 2.7lt. I have Checked/changed the fuses, replaced relays and bubs, and put in new ignition switch. Please help ran out of ideas.
i have a similar problem in my allroad and was that one of the headlights have the internals cables without the plastic cover and that was making a false contact i will recommend to check the cables
good luck
Lou
good luck
Lou
I had the same problem and I replaced my ignition switch but it started happening again. When I went to replace it the second time I noticed that the connection that goes to the load reduction relay had melted and was continuing to short it out. Make sure the female end of the connection is in good shape still, if not replace that and put a new ignition switch on it (if the old one is bad again). You could also check the load reduction relay as that turns off all the unnecessary electronics, ie radio, lights etc, when you turn the key from on to start. You can check that relay to see if it's bad by listening for relay chattering (it should click when it comes on) when you turn the key from off to on (not to start), it should click.
Hope that helps
Hope that helps
Just had this problem...
Just made this account to help you because I know how much of a **** this problem is. Cheers.
N'Syncro
33
02-16-2020 03:12 PM
Touge.ca
Canadian Discussion
09-02-2015 01:30 AM
