Help with 2001 2.7T !!!!
have a 2001 2.7t and for the last two weeks Ive been having starting issues when cold. It would crank, starts and rpm's would drop and it would shut off. After a few of these episodes back to back, it would be fine and drive normal.
A few days ago, I would come to a red light and the car stalled once adding to the first issue. Last night I had same trouble with starting and finally I took off and it kept stalling on me. The idle is very rough and doesnt respond to the gas pedal input at all, I idled it just enough to park it. Changed out the Coolant temp sensor as someone suggested but that didnt do anything. Any ideas? it did through a P0300 code for obvious reasons. |
Hmm try looking for intake leaks, or failed crankcase vent valve. Can you see fuel trim with your scantool?
interestingly, it was the mass air flow sensor!
