Delmed83 |
11-28-2012 09:59 AM |
Help Needed w/ Timing Service!!!!
Hey guys, this is my first timing service I've ever attempted and I am having issues. I got into this just to replace a thermostat that was leaking coolant at the o ring seal. While in there, I figure I would install a kit so everything would be new. Well, I bought the cam lock bar and the crank lock pin and using the ECS tuning installation instructions, I did everything correctly to my knowledge. I first started the car and it was fine but I noticed it had some vibration in the low rpm range. I thought maybe that was there and never noticed it. Well, while trying to bleed coolant I left the engine at 2k rpm's as the bentley suggests and when I dropped the rpm back down to idle, the car sounded like a diesel engine with clicking or clacking. I put one end of screwdriver onto valve covers and other end to my ear and valves sound ok. The first time I tore it back down the timing belt was loose and timing was off. In addition, the serpentine belt's inner rib was starting to get shredded. I put the old hydraulic piston tensioner back in and replaced the serpentine belt tensioner. Start it up....sounded fine....after revving...back to diesel sound. Tore it down again and belt was tight, almost too tight, but still in time. Any direction?
