HELP... P1242 Injector Circuit Open Cylinder 6
I can't figure it out. It's a stage 3 setup with Green Giants and a GIAC file. Here's what I've done so far...
I moved the injectors around, to see if the open circuit code would follow. It stayed in that cylinder.
I swapped ECU's between my stage 3 file, and a stock ECU. The code still pops up.
I've tested continuity of the wiring between the ECU and the injector, tests good.
I've sent all the injectors off to have them tested for resistance, flow, pattern, all that jazz. Everything was within spec.
The last thing for me to do, that I can think of, is actually replace the wiring and connections between the injector and the ECU.
If anyone has ANY other suggestions, please... chime in.
if it didn't follow the injector, it's the wiring.
continuity *might* show up okay while you are testing it, but when you put it back into position, maybe the wire then separates?
I'd say it's gotta be wiring.
Grifnsqest
07-20-2008 07:28 PM
