help Plzz my ESP,ABS and CEL are all on
Yesterday its been the coldest day of this fall in Upstate NY mabye like 25* to 30* degrees.I started my car to warm up and i went back inside when i came out the CEL was on.It was to late to go to any autozones to check it.So i slept on it.Today in the morning which is like 20* degrees outside i started the car CEL still on i let it warm up for like 5 min and started driving very slow cus i was late for work.As i was driving the ESP and the ABS lights came on.WHAT THE FUKKKKK PLZZZZZ HELP
You guys have any idea what it might be, is it the weather?Im goin to check the cel and ill let ya know what it says.
Got the codes P0441
ok i just got the codes to an advance auto place and this is what they read
DTC (codes)
P0441
EVAP emission
control system
purge flow fault
u guys know what that means. thanx
DTC (codes)
P0441
EVAP emission
control system
purge flow fault
Re: help Plzz my ESP,ABS and CEL are all on
My 03 2.7T 6MT did same thing.
Are your brake lights out also?
Dealer (Certified/Warranty)put in brake light switch, which worked for 2 miles. Then ABS Module, which at first didn't work either...turns out it was the module, but they had a coding problem on the new part. OK now. No idea what this would have cost, and probably don't want to know. Good luck.
Re: hard to say - check the CEL and let us know
ok i just got the codes to an advance auto place and this is what it reads
DTC (codes)
P0441
EVAP emission
control system
purge flow fault
DTC (codes)
P0441
EVAP emission
control system
purge flow fault
PKing688
02-01-2008 04:02 AM
jensenkd
VAG-COM Discussion
06-29-2006 07:06 AM
