how to change engine oil and oxygen sensor
Hi.
I know there are many tech articles that aren't posted in the tech article section. So does anyone know the link or section where I could find a dicrection with pictures for changning oil and O2 sensor myself?
doesn't have everything, but here's a good start
FYI, oil change is as simple as removing belly pan, remove oil drain plug bolt from oil pan, remove oil filter, reverse all the above, then refill with oil
oxygen sensors suck, and unless you are proficient with tools, I'd let someone else do it<ul><li><a href="https://forums.audiworld.com/s4/msgs/1559248.phtml">LI-S4's post</a></li></ul>
MingsS4
03-02-2018 05:34 PM
user 7208203
02-25-2004 02:10 PM
nicetts
02-04-2002 08:33 AM
