How should I be checking my oil?
Old 11-08-2006, 03:38 PM
New Member
1stVR6's Avatar
Default How should I be checking my oil?
Not to sound like a complete idiot, but how do you guys check your engine oil level for the 2.7T? It seems that when I check oil level soon after a drive, say at the gas station or something, the oil level appears high. When I check after engine has been resting, say after sitting in the garage for the night, the oil level is right on.
Which one should be believe? Any comments, suggestions, technical knowledge?
I know the 2.7T uses oil pressure to advance timing, could this be causing a certain amount of residual oil volume to deposite somewhere in the engine?
Thanks in advance...
Old 11-08-2006, 06:10 PM
quickaudi:STFA's Avatar
I check mine when it's warm.
Old 11-09-2006, 08:45 AM
New Member
Es4go's Avatar
On a level surface (before starting) in the morning. Wipe the stick and recheck.
Old 11-09-2006, 09:40 AM
Member
S4_Cinci (I S'edTFA)'s Avatar
Default Oil expands when it gets hot, thus normal for it to read up to 1/2 qt. higher when hot vs cold...
technically the level should be checked when hot, but I don't think it will hurt anything by having the oil "full" when cold. If you are using synthetic, it has a higher film stregth than dino oil so more will be "held up" on the engine internals. My theory is that while the car is running, at least 1/2 quart will be circulating through the engine and thus out of the pan, so the engine will never "see" the higher volume of oil that shows up on the dipstick when hot.
Too much oil in the pan can get splashed by the crankshaft and cause problems, but I'm pretty sure you would have to have it like a quart too full when cold to experience such an issue. [I always have my oil full at cold, or very close so that it is always slightly higher than full at full operating temp. - no problems so far with any of my vehicles over the past 30 years or so...]
Old 11-09-2006, 05:08 PM
New Member
1stVR6's Avatar
Default I found my own answer!
So, don't know why it didn't occur to me before to check my Bentley... duh!
It says test conditions are:
- Oil temp is above 60 degree C (140F)
- Vehicle must be level
- Wait a few minutes after shutoff to let oil levels settle
So... there you go.
a_very_naudi_guy
07-01-2018 09:24 AM
DillonM
S4 (B9 Platform) Discussion
01-18-2018 08:20 AM
Alex2.7T
07-18-2016 06:10 AM
jeffry
01-18-2012 04:15 PM
Ben3.2TT@BC
06-09-2001 10:41 PM
Quick Reply: How should I be checking my oil?
