K03/K04 Hybrid
K03/K04 Hybrid
I read in an earlier post about this turbo hybrid. Couple of questions.
How much horsepower would you get on an other wise stock car with the hybrid turbos? I understand the TIP transmission is rated to 315hp, will it exceed this?
Would you have to upgrade the cooling?
Are they easy enough to install for a semi-n00b with access to lifts? (Auto skills center on AF base)
Where is a good place to buy them if I decide to go that way?
What parts would you upgrade/replace to a stock 2.7T, besides the turbos? What if I left the K03's alone?
Thanks!
Thanks!
Answers...
-Your horsepower gains with only adding the turbos will be almost nothing. At most, I'd say 15 hp or so. No worries about the transmission.
-No cooling upgrades needed, although it's never a bad idea to upgrade the intercoolers.
-Not an easy install at all. You need to pull the motor. People have done it, but no one would ever call it easy for a first timer.
-Email Jacob Buehn (Imolavirus) at imolavirus@msn.com
He does good work.
-I wouldn't replace the turbos when stock unless you have a problem with them...there's no point really.
He does good work.
fjasper
06-04-2011 02:25 AM
CarterMarkham
17
06-09-2007 02:44 PM
porscheman
11
02-25-2004 11:07 PM
AdamB
01-20-2002 11:11 AM
