looking for opinions on logs of my 71k motor (MAF & Timing)...
...have had a lot of maintenace done, hadn't logged anything in a while, so I did some logging (VAG-COM), and i'm looking for thoughts on MAF g/s and Timing.
2001 S4 - H Box, Stock ECU, 71k miles
~60 F ambient, ~2k feet above sea level
MAF G/S (block 003)
Did a couple WOT 2nd and 3rd runs, max G/S value was 210.33
Average on the WOT 2-3 Run was 143.21
Timing d.BTDC (block 010)
Same runs, max d.BTDC was 40.5
Average on the WOT 2-3 run was 14.65
Boost (block 115)
Same runs, max 0.68 BAR actual
Average on the WOT 2-3 Run was 0.47 BAR actual
Though odd on the boost as my boost gauge (omori electrical with peak hold/warning) recorded a bit over .7 BAR (i set the warning at .7, and it went off, so something marginally over .7 bar on the boost gauge).
Thanks for any input.
MAF G/S (block 003)
Boost (block 115)
BLK01S4
11
12-12-2006 11:27 AM
