Misfire Help
Hey Guys,
So I'm getting a bad misfire while the car is idle. It runs fine otherwise. Here are the DTCs that came up: 16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit P0150 - 35-10 - - - Intermittent 17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High P1131 - 35-00 - - 17538 - Fuel Trim: Bank 2 (Mult): System too Lean P1130 - 35-00 - - 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-00 - - 16690 - Cylinder 6 Misfire Detected P0306 - 35-00 - - 16689 - Cylinder 5 Misfire Detected P0305 - 35-00 - - 16688 - Cylinder 4 Misfire Detected P0304 - 35-00 - - So far I've tried to change the spark plugs, swap ICMs and move coil packs around. Doesn't seem to be any of those. I'm kinda stumped at the moment. Any idea's or input? Thanks in advance. 2000 S4 |
replace your oxygen sensors.
Damn, this is so similar to a post on the B5 S4 forum...
=D
2nd, they cause misfires. Vast sells them for 200
bad EGTs? and yes they go bad and dont always leave a code.
