Misfires all cylinders bank 2 (4, 5, 6)
I've searched and read most threads on misfires. Causes appear to be mostly from:
1. sparks plugs 2. coil packs 3. icm 4. bad timing (maybe) 5. wiring (rarely) If ALL 3 cylinders in bank 2 (4,5,6 driver side bank) are misfiring consistently (every time I start the car) and I do NOT have ICMs (034 icm delete/2.0T coilpack conversion) … what else could be the problem? 1. I'll be replacing spark plugs, but they _look_ fine. 2. coil packs are nearly new, and unlikely that all 3 in one bank are failing when the other bank is fine 3. no icms 4. vag-com says timing is within spec, might replace the belt since it seems a bit stretched 5. … haven't tested for bad wiring |
Could possibly be the cam chain tensioner on that side?
If timing is fine, then tensioner wouldn't be the problem, most likely?
SOLVED: ICM replacement cables in the kit were not fully seated. DERP.
