My turbos make a high pitched sound when starting the car in the morning and then it goes away?
anyone know if this is bad. I have a 2004 a6 2.7t with roughly 60000 miles on it.
Re: My turbos make a high pitched sound when starting the car in the morning and then it goes away?
More than likely it's your secondary air pump. Located top middle of firewall, makes high pitch sound on startup. Tech archieve has repair writeup.
Sorry if took me so long to respond. It is not when boosting it is just in the morning. I will check the codes and let you know.
Thanks
Thanks
Did you find the source - currious to know the outcome
mine did as you describe, so I decided it was time to upgrade before a complete turbo failure (passenger side turbo turbine shaft had excessive play [movement])
devinsixtyseven
05-05-2011 08:28 AM
Audifan1
2.7T V6 Discussion
09-05-2008 10:03 AM
HooosUrDaddi
07-10-2006 08:54 PM
