Setting readiness problems (Cat. Converts and O2 sensors)
I just put a new motor in my 00' S4 and I am trying to get everything set for inspection. I have been able to get readiness to set with everything except for the catalytic converters and the O2 sensors. When I try to set block 034 in Basic Settings I can never get the test to run, it just says,"Test Off." I have gotten the cat temps to a bit over 400 degrees and still nothing. I have no fault codes and the car seems to be running good. Hopefully someone could give me some insight as to what the problem may be. I have searched religiously on here and could not find a solution.
Any help appreciated.
This is the right forum. Shut your pie hole xtreetoes.
Sometimes that test plan can be a bitch to set. Sometimes you just have to drive the car a few times before it will eventually set on its own. It doesn't necessarily mean there is any problems with the car. Just drive it for a couple of days and then go to measuring value block 86 or 87 and see if they are all 000000000 if they are then readiness set. Or just go to MVB instead of basic settings to look at individual readiness code status.
No prob, I realized that after I posted...
I have driven about 150 miles so far and have tried to set them three times and still can't get the test to turn on. I guess that is by biggest question, Why won't the test run?
No, I am not reclearing the codes because...
I don't have any. I drove the car about another 30 miles today and still nothing. All of my othere readines codes are set except for my cat. converts and O2 Sensors. I got the O2 sensor heating to pass. These are the only two holding me up from inspection.
Got these codes today...
Is this a sign of bad front O2 sensors? Is there anything else that would cause these codes like a boost leak or a vacuum leak?
Wednesday,31,October,2007,15:50:07:63549
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 8D0 907 551 A
Component and/or Version: 2.7l V6/5VT G 0003
Software Coding: 06611
Work Shop Code: WSC 13875
2 Faults Found:
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Readiness: 0010 0001
Address 01: Engine
2 Faults Found:
