Stumble Then C E L
Stumble Then C E L
To all the Tech gurus :
Last night I pushed the old girl hard , I felt a stumble and check engine light flashed then went off.
Vag codes :
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
17863 - Exhaust Gas Temp Sensor 1 (G235): Implausible Signal
P1455 - 35-10 - - - Intermittent
17870 - Exhaust Gas Temp Regulation for Bank 2: Implausible Signal
P1462 - 35-10 - - - Intermittent
Any thoughts ?
Vag codes :
P0300 - 35-00 - -
P0301 - 35-00 - -
P0303 - 35-00 - -
P0302 - 35-00 - -
Any thoughts ?
clear all of your codes and drive it and see what happens
gonna guess your EGT sensors probably caused all of them, though
well, either that or you have a boost leak - pressure test!
hhv011
08-19-2012 07:17 PM
