Suction jet pump
Suction jet pump
Ok, sorry if this has been covered, but I have searched and can't find anything on how to test this thing. Anyway my question is how can you test the suction jet pump to make sure that it's not clogged? If there is a way. I will be changing my valve cover gaskets this weekend since one side is leaking. I may also do the timing tensioner seals depending on how they look when I remove the valve cover. But I figured since I would be in that region, and that the suck pump is known to cause oil leaks I would test and change as needed. The car is a 2001 s4 by the way.
Thanks in advance for the help.
Re: What is a suction jet pump? Is that like a carburetor belt?
Its this,
http://worldimpex.com/assets/partimages/043053.jpg
Go to that link
Oh and real help is greatly appreciated
Go to that link
Re: Analogous to a PCV valve on old skool engines. Connected to the corrugated plastic hoses and fe
Exactly, Im going to change it out anyway.
Thanks for the help
Thanks for the help
acarney
01-15-2014 12:29 PM
Steelman93
06-14-2007 06:03 AM
shatiras
16
02-17-2005 11:58 AM
