tranny pan
tranny pan
I'm told that i have a dented tranny pan and that i should have it replaced for $800.
If I was out of transmission fluid would the car still run? How do I know how serious this is?
I don't think that a dented tranny pan would cause you to be out of fluid. However,
if you were out of fluid, the car would run for a while, then I imagine you'd get some serious lock-up and the car wouldn't move.
Sounds serious to me, but $800? hmmm.....
I know with an dented oil pan you can starve your pump but I don't know how the tranny looks inside
I'm guessing that there is where the concern lies.
The only way to check the fluid is from underneath the car. If you were out of fluid the tranny
wouldn't function. If it was severely dented, it might impact the filter, but it would have to be a major dent.
I would be concerned about the quotes you have received - the $40 for fluid is WAY LOW! It cost me $15 per liter, and it takes like 6 to 7 liters of fluid with the filter change. Sounds like they are not using the proper fluid - it needs to be a ZF (tranny manufacturer) approved fluid, not universal ATF stuff.
You'll have to get under the car to see how serious this is, but any seepage of fluid from the pan gasket area needs to be addressed. These trannys are sensitive to low fluid and are expensive to replace/rebuild.
Re: The only way to check the fluid is from underneath the car. If you were out of fluid the tranny
thanks - I bit the bullet and replaced the pan, changed the filter and fluid.
I'm sure it wasn't cheap to do that, but these trannys are a bit on the delicate side and cost a lot
to repair/replace. Likey made a good, safe choice. I would have done the same. I'd rather spend extra on maint and repairs than get stranded or hit with a huge bill because I tried to risk or push it.
ck256
12-09-2007 07:03 PM
KaMaKaZieP -ALUMIN8-
14
01-25-2004 08:45 AM
kaynos
08-28-2003 05:38 AM
