Vacuum Tubing hard?
Old 06-07-2013, 03:28 PM
Default Vacuum Tubing hard?
Going over the engine, I found that the vacuum line between the two front divert air valves has the cloth covering coming off one end. I started to look for a cracked line, but found the one side was soft and pliable, but the other, that still has the cloth cover was hard as a rock. Could this be clogged?
I took pics, but can't get them off my danged phone...
zeeborg is offline
Old 06-07-2013, 04:39 PM
Just replace ALL the lines you can get to.
ddillenger is offline
Old 06-07-2013, 06:26 PM
Sounds like a plan.
Can;t hurt, and looks like the tubing is cheap.
What should i use to replace the factory camps? Just regular SS band clamps ok?
zeeborg is offline
Old 02-03-2014, 12:45 PM
Moncho's Avatar
I used tension hose clamps and they seem to work just fine.
Moncho is offline
Airbag
09-06-2010 09:02 AM
RR
05-30-2005 04:49 PM
ThunderGrey27OffSuit
12v V6 Discussion
08-13-2004 09:11 PM
Paul H. (near Annapolis, MD)
05-18-2001 09:48 AM
Quick Reply: Vacuum Tubing hard?
