oil grade
what is the recommended oil grade for the 2019 q7?
Wing, what country are you writing from? What engine?
Welcome aboard !! |
Thanks Uberwgn, I'm writing from the US, east coast and my engine is the 3.0l
The required oil will be either quality standard 504.00 or 502.00. You need to open the hood and there will be a label just above where the radiator sits in the car. That will call out which VAG spec they want you to use. The 502.00 oils are e-z to track down.
Thank you again for your help.!!
My pleasure.
Originally Posted by uberwgn
(Post 25250332)
Originally Posted by angrypengu
(Post 25251942)
Are you absolutely sure the Q7 doesn't have the EA839 engine that requires 508.00?
Originally Posted by wingdiver
(Post 25252013)
No,my Q7 has the 3.0L engine and on top of the radiator I found the two stickers with the recommended oil grade 504.00 and 502.00. After some research I found that one is a 5w30 and the other is a 5w40 grade. I’m still confused why Audi gives me a choice of 2 grades of oil for this engine. |
Is that The Castrol Syntec European Formula? Where can I buy it? Audi dealer? |
