2005 A6 3.2 - octane question
Hi - what octane level are you running in your US 3.2's? What is the min octane...and have you seen performance(response/mpg) with increase octane over the min or is it a waste of money?
Thanks.
Jeff
Thanks.
Jeff
Re: the A6 has a v6 not vr6 configuration...octane is good ..better long term life..>
Actually i dont think there is a proper forum for the 3.2 v6 as it is a 24v DOHC motor to my knowledge, it may not be a VR6 but this might as well be the forum for it i guess.
Any way, an octane rating past what the motor recommends (91 octane) will not give you any significant gain unless your motor is chipped and has a program for above 91 octane or has some other modification to it beyond an intake or an exhaust. However, if your motor has a problem with early detonation you should look into a higher octane fuel as a temporary fix but in the long run its best to get the problem repaired.
hope that answers your question
Dumb gas question: Since octane rating is supposed to be percentage of octane, how is there 105, etc
ATH
05-19-2004 10:36 PM
