ABS Lights
ABS Lights
Hello anyone who can help! My vehicle now has an intermittent warning signal --- the brake light comes on and ABS light flashes. When this is on, the ABS is not working. When it is off, it works OK (tested on our dirt road). I took it in today for an inspection (and felt like I went to the proctologist) --- they said I needed an ABS module. They replaced it 2-3 years ago, with a used one, and told me that the 1998 original modules had a small wire that broke from fatigue. Sounds fishy. Any ideas on where I should start?
Interestingly, and also fishier, they also told me that there was an "oil leak," and that it needed to be fixed to pass inspection. This is simply not true (see above; not that there are not leaks, but this is not an inspection item).
Thanks!
Thanks!
I though it was generally the newer ones that had ABS problems
like the 1999 and newer.
Usually when an ABS module is truly bad VAGCOM won't recognize the module. What's the status on yours?
Pull the electrical connector and check for any corrosion or broken wires. Double check associated fuses and relays.
Modulemaster has a good reputation.
Junkyard parts are always a less expensive option.
My 1998 A4 ABS was replaced at 8 years ~140K
That was just before I got the car. I think the $700 bill the previous owner had to paid was the last dime he was going to put into that car.
try cheap-abs.com
Give Matt at cheap-abs.com a call. He has a lifetime guarantee and $110 includes return shipping. he is fast turn around - he received my module on Wednesday repaired it and mailed it back on Friday! One week including mail time both ways. The Bosch 5.3 ABS module is all he does.
Omega Supreme
05-18-2008 02:59 AM
Ok, have the VAG hooked up to my car with the ABS light on. Can't connect at all with the ABS proble
S4Del
12-12-2003 04:23 PM
