help me plz 99 audi a4 2.8 check engine codes p1626 and p1392
p1392 is camshaft sensor or off time by a tooth. which is it thought?? i want somones opinion it has 160kmiles runs and drives good jus check engine light is on. an the timing hasnt been touched by me .bought i jus purchased the car also.an p1626 is also coming up missing data message from tcm but my car is 5spd so i dnt kno iwas told to check under the passenger side seat for tcm and check if it is wet and if theres any water there!but let me know your opinions and how to diagnosis it. i planed on jus replacing the camshaft sensor but how do i kno which one it is. and where is it exactly located and is it easy fix. iam mechanicly inclined but its got me stumped jus a bit.and need some help diagrams. watever u got to help me
For the missing data bus from the tcm, Sounds like an incorrectly coded gateway, so the network thinks there should be an automatic transmission. Could also be possible you have the Engine controller coded for an automatic car.
The cam sensor could have just failed, have you tried replacing it? Is the engine noisy? really down on power? missing? Anything to suggest out of time? They do fail, its nothing rare. But its common for people to do crappy repairs to these engines and get timing belts off or chains off a tooth. Its also common for the chain tensioners to fail or have the pads break away.
thankyou
ya im replacing as soon as i can been busy with work . i think its jus the cam sensor have the new one jus waiting to install it .so like its on time stil have lots of power.no lag motor sounds great. no engine noise.idles perfect almost perfect little high then normal but not badd idles at 1 rpm.and the other thing im not too sure iwas thinking that it was mayb coded for a auto tranny but i was thinking maybe its jus the tcm wet or moist too much ill find out an let you what happens thanks for your advice helps alot
ichanged the one camshaft sensor but cannot locate both
i only can find one of the 2 camshafts sensors where are they both located please need some more advice. i change the one in the front of engine near timing belt where is the other one
audi42.8
06-14-2012 04:07 AM
chrisxiv
06-28-2007 06:58 AM
fan4F1
Audi 100 / A6 (C4 Platform)
14
01-01-2003 03:59 PM
