Help with valve cover leak....
I had the valve cover gaskets replaced to fix a rather obnoxious leak. The replacement fix most of the leak but now it is leaking from the front driver's side corner. I had the mechanic redo it and it did not fix the problem. I know the 2.8L is notorious for valve cover leaks. Is the front corner typical for this problem. Is there a "trick" to remedy this? Is it possible the cover itself is slightly warped causing the leak?
Any help would be appreciated.
gateway
02-27-2011 06:08 PM
90sportin
Audi Original "S" Cars
9
04-09-2005 07:43 AM
SiV6Qcoupe
03-14-2003 06:23 AM
