Misfires
Old 01-03-2008, 05:16 AM
einnod17's Avatar
Default Misfires
As previously discussed, I had all six coil packs replaced due to all six misfies, supposedly. Engine misfired again yesterday, so there must have been something else wrong. Would a cam position sensor cause a mis fire? It only seems to happen when i am driving hard. Could it be as simple as some bad plugs or anything? I have 112k on the car now.
Old 01-03-2008, 03:49 PM
New Member
BONFIRE074's Avatar
Default did you try the spark plugs in the first place?
i would start there, cheap enough to do and not too hard
Old 01-04-2008, 06:23 AM
einnod17's Avatar
Default Re: did you try the spark plugs in the first place?
No. When I took it in the car was barely driving. When they replaced the coils, it seemed to be fixed. Now about 3k miles later, here we go again.
Old 01-04-2008, 09:29 AM
New Member
BONFIRE074's Avatar
i would def try doing the spark plugs, then/and/or vag it to find which cyl is misfiring
Old 01-05-2008, 05:03 AM
No Bozos!
squidix9's Avatar
Default Lot's of things
But first I would look for codes before you do anything else. See if it tells you anything.
Some common misfire culprits:
Plugs - and a lot of oil around the outside of them
Wires
Coils
Knock sensors
Engine grounds
POS
Old 01-08-2008, 04:07 AM
Tech Guru
4Driver4's Avatar
Don't forget coolant temp sensor.
Old 01-08-2008, 04:43 AM
No Bozos!
squidix9's Avatar
Default Usually you see it run really rich along with that
When monitoring mine I see ir run real rich. Then when the intake air sensor flips it smooths out dramatically. A bit later when the coolant temp trips, the mileage gets a lot better too.
Old 01-09-2008, 03:52 AM
Tech Guru
4Driver4's Avatar
Default Agreed. But any time there are unexplained misfires with no code for anything else...
...I start with the coolant temp sensor. Cheap, easy, known for failure, causes havoc without throwing codes.
Old 01-10-2008, 05:03 AM
Member
S4_Cinci (I S'edTFA)'s Avatar
Default Don't forget the Ignition Control Modules - two solid state devices on top of the airbox. You can
usually swap them and watch the misfires switch cylinders, if you have VAG-COM and can see individual cylinder misfires.
Old 01-10-2008, 05:20 AM
No Bozos!
squidix9's Avatar
That works
Audi0007
30v V6 Discussion
04-07-2008 07:29 AM
GVee
Audi 100 / A6 (C4 Platform)
9
11-05-2007 07:11 AM
kairo77
10-15-2007 12:15 PM
Snow Trooper *Swiss*
10
10-11-2006 10:46 PM
Imolsify
03-31-2006 04:41 PM
Quick Reply: Misfires
