Go Back  AudiWorld Forums > Technical Discussion > Engines > 30v V6 Discussion
Reload this Page >
Where to start with these fault codes? Engine starts but stalls immediately. 3.0L V6
Old 04-09-2018, 06:48 AM
Default Where to start with these fault codes? Engine starts but stalls immediately. 3.0L V6
Hi Guys,
This is my first post in the forum, Im hoping someone can be of assistance here.
Long story short, my 2003 A3 3.0 Quattro will not start. It will turn over and run for about 1 second after which it stalls. I borrowed a code reader which came up with the following 8 fault codes. Any help with respect to which components are typically the cause for this no-start issue and these codes is hugely appreciated. Thanks in advance!
8 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 004 - Open Circuit - MIL ON
17936 - Camshaft Timing Adj. Bank1 (N205)
P1528 - 004 - Open Circuit - Intermittent
17464 - Bank1; Exhaust Cam Adjustment Circuit
P1056 - 002 - Short to Ground - Intermittent - MIL ON
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
16685 - Cylinder 1
P0301 - 001 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 001 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 001 - Misfire Detected - Intermittent
16705 - Engine Speed Sensor (G28)
P0321 - 008 - Implausible Signal
Readiness: 0110 1101
jmott76 is offline
Old 04-09-2018, 06:53 AM
Correction on my previous post, its an Audi A4, not an A3.
jmott76 is offline
Max_Power
11
04-24-2009 11:42 AM
as4driver
11-10-2008 03:10 PM
T0M3K
30v V6 Discussion
08-07-2007 06:20 AM
gtreng1
03-20-2007 05:17 AM
Gibson6594
08-06-2004 08:26 AM
Quick Reply: Where to start with these fault codes? Engine starts but stalls immediately. 3.0L V6
