1990 quattro v8
1990 quattro v8
Hello, I just replaced the fuel pump and relay on my 90 v8..car will run about ten mins and die..needs to sit a while before it will re start..is there an ignition problem for this year? Has anyone else had this problem?
Re: 1990 quattro v8
Sounds like a crank referance sensor. located on the driver side block along with engine speed sensor.they are both mounted in the same bracket helt in with two 8mm screws. Feel free to post your early 4.2(abh) or 3.6 (pt) ENGINE questions here, as there is at least one of us hear that can help you.
v8quattro
09-30-2011 12:45 PM
applehugger
04-20-2011 05:04 PM
seal
12-27-2003 05:31 PM
