2004 Audi s4 won't even crank over
Hey I have a 2004 Audi s4 4.2 manual trans when I attempt to start it it won't start, won't even try and crank over, I'm ordering a new clutch switch but is there anything I can check besides that? Don't want to spend a arm an a leg having it towed somewhere please help! Thanks!
Well the starter could be bad. Its hell to get to. You would need to check if its getting its trigger or not, If it is, the starter is junk, if its not, then clutch switch, ignition switch, start relay, wiring.
