4.0 TFSI
4.0 TFSI
Don't see a section for this engine so I thought I would try here. Changed the PCV/ oil separator. Before replacing the PCV/oil separator with the engine at idle you could barely remove the oil cap there was so much vacuum in the crank case. After replacement its quite easy to pop the oil cap open when running at idle. There is however a decent amount of vacuum still. Is this normal on this engine? Could some one be so kind as to confirm this for me please and thank you.
CHIZEN
13
07-11-2005 06:42 AM
