B6 S4 - Been sitting for 3+ weeks in garage - any special precautions before start-up?
Old 08-23-2007, 06:17 AM
Silver Stealth's Avatar
Default B6 S4 - Been sitting for 3+ weeks in garage - any special precautions before start-up?
I did hook up a trickle charger to the battery for a bit and it is fine.
I know from past experience when traveling for work (1-2 weeks) that this engine doesn't like to sit. Never let it sit for this long though.
I didn't add a fuel stabilizer but maybe should have in hindsight.
Anything else to be concerned about prior to cranking it up?
Old 08-23-2007, 09:34 AM
1elcapitan's Avatar
turn key and let is cycle completely!!
Old 08-30-2007, 10:03 PM
atisvt99's Avatar
Default Re: turn key and let is cycle completely!!
Most engines are like this... Turning the key to the 'on' position (but not actually turning it over) will prime the fuel system (and you can certainly hear the fuel pump doing its thing when you do!). You can actually do this a couple of times to make sure that your rails and injectors have fuel after sitting for a while... but other then that, I can't imagine anything else you would need to do other then starting it and letting the internal lubrication system take it from there for a minute or two.
Jaimo
10-15-2015 07:48 AM
Audinado
4.2 V8 Discussion
03-05-2012 07:31 AM
Audinado
04-01-2011 07:59 PM
BoxcuTTer
06-14-2006 06:16 AM
Octane
05-25-2005 03:52 PM
Quick Reply: B6 S4 - Been sitting for 3+ weeks in garage - any special precautions before start-up?
