ECM failure?
Our 2008 4.2L Q7 all of a sudden has started running very rough (still starts) and has a ton of error codes. This just happened all of a sudden, so it seems one of these codes is the real problem and rest are just related issues. I'm assuming it's the ECM and I need to replace it? Thoughts?
00135 Fuel rail system pressure too low 08852 Fuel pressure regulator 2 control circuit 00768 random/multiple cylinder misfire detected 00776 cylinder eight misfire detected 00774 cylinder six misfire detected 0101112 evaporative in mission system the purge control valve circuit low 05173 secondary air injection pump relay J299 short circuit to ground 05153 secondary air inlet valve N1 12 short circuit to ground 05255 Secondary air injection secondary air injection valve 2 N3 20 short circuit to ground 00258 mass or volume airflow circ low input 00268 mass or volume air flow B circuit low input 04763 fuel pressure regulator valve bank to open circuit 01314 engine control module ECM - please read DTC |
