ECU swap gone wrong 2011 S5 - Got a automatic ECU
Team,
So first my sob story, was supposed to move to texas on the 3rd, car died the night prior. Litterally had just parked the car and shut her down, got out walked 10 feet realized I couldnt park in that spot, got back in and lit up like a xmas tree. My buddy/neighbor tried jumping with his GTI and nothing. Hooked it up to vcds....
So with all my **** packed in the u-haul my room mates took off and I got my car towed to a shop. They trickle charged it and tested all relays and fuses. Once those all were found to be good he tested the leads to the ECU, and all apparently were fine. So I ordered an ECU on ebay for 150 bucks by looking up "8t0907560" now the major mistake there was not including the letters that follow.... I got an AD and not AB which was in my car prior. Audi tried to reflash it to manual but were unsuccessful in giving it the manual flash, which I am kinda curious if they used the current part number to find the flash. Going to talk to them on monday when they are open about it. So I came by after they gave the bad news and did another data dump...
So I tried changing the engine settings from 01140009190F0120 to 01140009180F0120 and it kept spitting out an error.
Anyone know of a way to force the change?
Does anyone know how to get the security access key?
What version of immoilibzer was used on these batch of s5's?
Spoiler
Sunday,02,June,2019,21:54:07:58285
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
Chassis Type: 8T0
Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
6C
Mileage: 192610km-119682miles
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine Labels:
VCID: 55F7828FEC0F6C7FC97-FFFE
Note: Excessive Comm Errors
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0050
Revision: -------- Serial number: --------------
Coding: 110D18
Shop #: WSC 06325 000 00000
VCID: 025D89D344012BC7DC5-8056
4 Faults Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 192217 km
Time Indication: 0
Date: 2010.08.10
Time: 19:43:54
Freeze Frame:
Hex Value: 0x7A00
Hex Value: 0x4006
Hex Value: 0x1237
Hex Value: 0x1FB2
Hex Value: 0x00FF
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 6
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:08
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0722
Hex Value: 0x122B
Hex Value: 0xB998
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:09
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x2722
Hex Value: 0x1232
Hex Value: 0x0298
Hex Value: 0x00FF
008 - Implausible Signal
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:08
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0722
Hex Value: 0x122B
Hex Value: 0xB998
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG
Component: BCM2 2.0 H04 0430
Revision: 00002001
Coding: 0F0000
VCID: 77ABE8071FC37E6FFBB-8022
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0210000112900006
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:55:09
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 C HW: 8T0 959 760 C
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00001010182726
Coding: 00017025002C00000000
VCID: 43D34CD71B9BE2CF973-8016
No fault code found.
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01240620100280
Coding: 48122000
VCID: 005983DB4A0D39D7CA1-8054
2 Faults Found:
03269 - Functionality Linited due to Energy Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 21:52:05
Freeze Frame:
Fault Status: 01101000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:08
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H29 0392
Revision: 10029001 Serial number: 00000000576354
Coding: 26001091063CAF010000080300003D3D0F1C13880201016100 0000
VCID: 3C21372B66659D37D69-8068
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 260610 H14 0070
Serial number: SWF10060265537
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10963949
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN
Component: E1 - LDS H08 0090
Serial number: 00000000001606101989
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:55:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 192027 km
Time Indication: 0
Date: 2010.08.01
Time: 14:44:00
02258 - Door Opener Transmitter
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 192027 km
Time Indication: 0
Date: 2010.08.01
Time: 14:44:00
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51241018214386
Coding: 200002
VCID: 47CB58C72FA3CEEF4BB-8012
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H41 0610
Serial number: 003GLD0G89YY
Coding: 303338334330303030304A55304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 45D752CF152FDCFFB97-8010
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R1000000EEE
Crash sensor for side airbag: driver side:
Serial number: 6334MSME550266748
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME55326646B
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME3F59513CU
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME42532B049
Crash sensor for front airbag: driver side:
Serial number: 63732SME13624304M
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME61654820W
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
Component: Lenks.Modul H06 0156
Revision: 00000000 Serial number: 20100702000181
Coding: 000016
VCID: 49CF5EFF39B7389F5DF-801C
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 983 D HW: 8T0 920 983 D
Component: KOMBIINSTR. H38 0258
Revision: 00000000 Serial number: EI118ZU5A
Coding: 8B1501000300D705020000
VCID: 3FDB40277773862FF3B-806A
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:09
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E1061400B5
Coding: 00C303
VCID: 03538CD75B1B22CFD73-8056
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 10020AEB180610
3 Faults Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 129
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:38
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.20 V
Count: 7
Bin. Bits: 10011
Time: 0.40 s
01312 - Powertrain Data Bus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 129
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:39
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.20 V
Count: 7
Bin. Bits: 10011
02252 - Generator
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 21:51:45
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.30 V
Count: 6
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00001010182838
Coding: 00197B25002C00000000
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C13224E00120102
VCID: 53F37C97EBFB724F273-8006
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0132032189
Coding: 0106029A00FA444580B0003200000000
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Serial number: 0123456789ABCDEFGHIJ
2 Faults Found:
03233 - Controls for Garage Door Opener (E284)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 63
Mileage: 192027 km
Time Indication: 0
Date: 2010.08.01
Time: 14:44:47
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:55:09
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34882003220401
VCID: 7AADF1332CD16307845-802E
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
VCID: 52FD7993D4E17B472C5-8006
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000677599
Shop #: WSC 00000 000 00000
VCID: 34311F0B4E3555771E9-8060
2 Faults Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 4
Fault Frequency: 7
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:09
Freeze Frame:
Voltage: 12.30 V
Count: 58
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0202
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 4
Fault Frequency: 11
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:09
Freeze Frame:
Voltage: 12.20 V
Count: 64
Speed: 0.0 km/h
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0202
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000002
VCID: 392F2E3F6557A81FCDF-806C
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:08
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471FO0A7512510
Coding: 020007010000000001
VCID: 5DE79AAF9D3FB43F817-8008
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 664 C HW: 8T1 035 664 B
Component: H-BN-NA H49 0116
Revision: -------- Serial number: 490G%0A7573636
Coding: 010200020206A1EF41000B0E000000030000
VCID: 38292B3B525DB117321-806C
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H42 0094
Serial number: 9466GR0A0031771
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000574669
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H04--- Serial number: 525PA8-J0491XW
Coding: 1000008
VCID: 38292B3B5E5DB117321-806C
End----(Elapsed Time: 01:58, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
www.Ross-Tech.com
Chassis Type: 8T0
6C
Coding: 110D18
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 192217 km
Time Indication: 0
Date: 2010.08.10
Time: 19:43:54
Freeze Frame:
Hex Value: 0x7A00
Hex Value: 0x4006
Hex Value: 0x1237
Hex Value: 0x1FB2
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:08
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0722
Hex Value: 0x122B
Hex Value: 0xB998
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:09
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x2722
Hex Value: 0x1232
Hex Value: 0x0298
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:08
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0722
Hex Value: 0x122B
Hex Value: 0xB998
Hex Value: 0x00FF
Revision: 00002001
Coding: 0F0000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:55:09
Coding: 48122000
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 21:52:05
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:08
Coding: 00FD11
Coding: 02532C
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:55:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 192027 km
Time Indication: 0
Date: 2010.08.01
Time: 14:44:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 192027 km
Time Indication: 0
Date: 2010.08.01
Time: 14:44:00
Coding: 200002
Coding: 000016
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:09
Coding: 00C303
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 129
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:38
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.20 V
Count: 7
Bin. Bits: 10011
Time: 0.40 s
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 129
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:39
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.20 V
Count: 7
Bin. Bits: 10011
02252 - Generator
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 21:51:45
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.30 V
Count: 6
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 63
Mileage: 192027 km
Time Indication: 0
Date: 2010.08.01
Time: 14:44:47
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:55:09
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:09
Freeze Frame:
Voltage: 12.30 V
Count: 58
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0202
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:09
Freeze Frame:
Voltage: 12.20 V
Count: 64
Speed: 0.0 km/h
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0202
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
Mileage: 192619 km
Time Indication: 0
Date: 2010.08.27
Time: 20:54:08
Coding: 1000008
Spoiler
Friday,14,June,2019,17:25:32:58285
www.Ross-Tech.com
VIN: WAU3VAFRXBA009762 License Plate:
Chassis Type: FR-AU48 (8T0)
6C
VIN: WAU3VAFRXBA009762 Mileage: 192610km-119682miles
01-Engine -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
Address 01: Engine (J623-CAUB) Labels:. 079-907-560-CAU.clb
Part No SW: 8T0 907 560 AD HW: 8T0 907 560
Component: 4.2l V8/4V H22 0001
Revision: 76H22---
Coding: 01140009190F0120
VCID: 7CA1F72B26E55D37969-8028
1 Fault Found:
049409 - No Communication with Transmission Control Module
U0101 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 39.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.811 V
Readiness: 0110 1101
Coding: 110D18
Shop #: WSC 46268 003 1048576
2 Faults Found:
02757 - Learning Tire Pressures
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0037
Hex Value: 0x3993
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:55
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0032
Hex Value: 0x0293
Hex Value: 0x00FF
Revision: 00002001
Coding: 0F0000
Coding: 48122000
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Coding: 00FD11
Coding: 02532C
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Coding: 200002
Coding: 000016
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:56
1 Fault Found:
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Freeze Frame:
Voltage: 11.80 V
Count: 66
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Coding: 0000002
Coding: 1000008
End----(Elapsed Time: 01:31, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
www.Ross-Tech.com
6C
Revision: 76H22---
1 Fault Found:
U0101 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 39.0°C
Voltage: 11.811 V
Coding: 110D18
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0037
Hex Value: 0x3993
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:55
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0032
Hex Value: 0x0293
Hex Value: 0x00FF
Revision: 00002001
Coding: 0F0000
Coding: 48122000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Coding: 00FD11
Coding: 02532C
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Coding: 200002
Coding: 000016
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:56
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Freeze Frame:
Voltage: 11.80 V
Count: 66
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Coding: 0000002
Coding: 1000008
Spoiler
Friday,14,June,2019,17:27:13:58285
www.Ross-Tech.com
VIN: WAU3VAFRXBA009762 License Plate: NEW_ECU
Mileage: 192610km-119682mi Repair Order:
6C
Revision: 76H22---
1 Fault Found:
U0101 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 39.0°C
Voltage: 11.811 V
Coding: 110D18
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0037
Hex Value: 0x3993
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:55
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0032
Hex Value: 0x0293
Hex Value: 0x00FF
Revision: 00002001
Coding: 0F0000
Coding: 48122000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Coding: 00FD11
Coding: 02532C
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Coding: 200002
Coding: 000016
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:56
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Freeze Frame:
Voltage: 11.80 V
Count: 66
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Coding: 0000002
Coding: 1000008
Address 01: Engine Labels: 079-907-560-CAU.clb
Control Module Part Number: 8T0 907 560 AD HW: 8T0 907 560
Component and/or Version: 4.2l V8/4V H22 0001
Software Coding: 01140009190F0120
Work Shop Code: WSC 06325 000 00000
1 Fault Found:
U0101 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 39.0°C
Voltage: 11.811 V
Address 01: Engine
Advanced Identification
Identification: BPG-810
Revision: 76H22---
Date: 23.11.10
Manufacturer number: 1480
Test stand number: 0512
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Programming Status: 00000000
Flash Tool Code: 00000 000 00000
Misc.
Hardware number: 8T0 907 560
Workshop System Name: J623
Car Info
Chassis Number: WAU3VAFRXBA009762
Engine code: CAUB
VCDS Info:
Readiness: 079-907-560-CAU.crd
Address 01: Engine
Revision: 76H22---
Date: 23.11.10
Flash Status
Misc.
Car Info
Engine code: CAUB
VCDS Info:
1 Fault Found:
U0101 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 39.0°C
Voltage: 11.811 V
Address 01: DTCs cleared
Address 01: Engine
Revision: 76H22---
Date: 23.11.10
Flash Status
Misc.
Car Info
Engine code: CAUB
VCDS Info:
6C
Revision: 76H22---
1 Fault Found:
U0101 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 04:50:03
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 23.0°C
Temperature: 32.0°C
Voltage: 11.811 V
Coding: 110D18
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0037
Hex Value: 0x3993
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:55
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0032
Hex Value: 0x0293
Hex Value: 0x00FF
Revision: 00002001
Coding: 0F0000
Coding: 48122000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Coding: 00FD11
Coding: 02532C
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Coding: 200002
Coding: 000016
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:56
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Freeze Frame:
Voltage: 11.80 V
Count: 66
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Coding: 0000002
Coding: 1000008
End----(Elapsed Time: 01:25, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/000/00000),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140109180F0120, (06325/123/12345),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140109180F0120, (06325/0/00000),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140109180F0120, (06325/0/000000),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/0/00000),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/0/000000),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/97/997),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009190F0120, (06325/123/12345),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009180F0120, (06325/123/12345),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009000F0120, (06325/123/12345),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009200F0120, (06325/123/12345),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009170F0120, (06325/123/12345),
Address 01,8T0 907 560 AD,recoded (Long Coding),from,01140009190F0120,to,01140009980F0120, (06325/123/12345),
Control Module Part Number: 8T0 907 468 AD
Component and/or Version: GW-BEM 4CAN-M H09 0117
Software Coding: 00C303
History Data
Record 1/16: No-load voltage underranging
2019-02-18-07:55*16.7*02*08050***
2019-02-17-07:55*24.0*02**
2019-02-16-07:55*24.0*02**
2019-02-15-07:55*24.0*02**
2019-02-14-07:55*24.0*02**
2019-02-13-07:55*24.0*02**
2019-02-12-07:55*24.0*02**
2018-11-11-11:55*13.3*02*00468***
2018-11-10-11:55*24.0*02**
2018-11-09-11:55*24.0*02**
2018-11-08-11:55*24.0*02**
2018-11-07-11:55*24.0*02**
2018-11-06-11:55*24.0*02**
2018-11-05-11:55*24.0*02**
2018-10-27-16:49*00.0*02*00000***
2018-10-23-14:48*00.0*02**
2000-01-01-00:00*00.0*00**
Record 2/16: No-load current overranging
2010-02-04-23:34*0004*052*-00.25*0-0-0-0-0-0*0*02*00004**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
Record 3/16: Shut-off stage history
2010-07-31-13:13*1*0*026*005*-10.56*0-0-0-0-0-0*0*0*00.0*00.0**
2010-07-31-07:23*1*0*026*004*-10.22*0-0-0-0-0-0*0*0*00.0*00.1**
2010-07-31-07:20*1*0*027*004*-10.80*0-0-0-0-0-0*0*0*00.0*00.0**
2010-07-31-07:16*1*0*027*005*-11.95*0-0-1-0-0-0*0*0*00.0*00.0**
2018-10-27-16:58*3*0*009*000*-06.64*0-0-0-0-0-0*0*0*00.0*00.3**
2018-10-27-16:57*1*0*011*000*-06.86*0-0-0-0-0-0*0*0*00.0*00.2**
2018-10-27-16:51*3*0*012*000*-07.03*0-0-0-0-0-0*0*0*00.0*00.2**
2018-10-27-16:51*1*0*013*000*-07.26*0-0-0-0-0-0*0*0*00.0*00.2**
2018-10-26-21:29*3*0*010*000*-06.60*0-0-0-0-0-0*0*0*00.0*00.2**
2018-10-26-21:28*1*0*011*000*-07.35*0-0-0-0-0-0*0*0*00.0*00.2**
2018-10-24-08:37*3*0*015*000*-04.56*0-0-0-0-0-0*0*0*00.0*00.1**
2018-10-24-08:36*1*0*015*000*-07.20*0-0-0-0-0-0*0*0*00.0*00.1**
2018-10-24-08:33*1*0*016*000*-06.55*0-0-0-0-0-0*0*0*00.0*00.1**
2018-10-24-08:21*3*0*021*000*-05.68*0-0-0-0-0-0*0*0*00.0*00.0**
2018-10-24-08:20*1*0*021*000*-07.24*0-0-0-0-0-0*0*0*00.0*00.0**
Record 4/16: Battery change history
2010-01-22-00:07*02*000915105DL*VAO*331121L2GD*09891*09168*00 00*0000*0000**
2010-07-07-02:37*01*8K0915105F *VA0*300629T0QG*10004*05649*0000*0000*0000**
2000-01-01-00:00*00*-----------*XXX*----------*09999*00000*0000*0000*0000**
2000-01-01-00:00*00*-----------*XXX*----------*00000*00000*0000*0000*0000**
Record 5/16: Energy-critical vehicle states
2018-10-23-13:54*+00.00*-11.81*-69.17*10.12*000*09*+00.0*08143*09980*
187719*0-0-0-0-0-0*0*00.0*00.0*000.0*00*01*01**
2013-05-05-21:02*-00.23*-00.52*-03.20*11.73*000*09*-15.2*03905*09945*
040914*0-0-0-0-0-0*0*00.0*00.6*029.1*43*00*01**
2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*0000 0*00000*
000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**
Record 6/16: Energy balances (last 20 trips)
2010-01-29-03:50*038*+32*-005.9*00.08**
2010-01-24-05:48*066*+27*-000.3*00.00**
2010-01-23-00:29*041*+23*-004.9*00.06**
2010-01-22-21:57*052*+18*-001.8*00.02**
2010-01-22-00:47*100*+23*+000.0*00.01**
2010-01-22-00:34*100*+22*-000.1*00.00**
2010-01-22-00:04*100*+22*-002.4*00.03**
2010-01-22-00:00*100*+26*-000.1*00.00**
2010-08-28-12:29*004*+20*-001.3*00.02**
2010-08-28-12:26*004*+20*-002.1*00.03**
2010-08-28-09:13*005*+17*-004.8*00.07**
2010-08-27-22:03*017*+23*-001.4*00.02**
2010-08-27-21:50*017*+23*-016.7*00.21**
2010-08-27-21:12*047*+21*-000.1*00.00**
2010-08-27-21:05*049*+21*-000.1*00.00**
2010-08-27-20:55*044*+21*-000.2*00.00**
2010-08-27-20:54*047*+21*-000.1*00.00**
2010-08-27-20:50*051*+21*+001.5*00.04**
2010-08-27-12:39*058*+17*+000.2*00.04**
2010-08-25-02:00*065*+27*+004.4*00.65**
Record 7/16: Energy balances (last 20 standing times)
2010-02-02-04:53*027*-001.9*000.1*00.1*00.1**
2010-02-02-04:23*027*-004.6*000.4*00.3*00.3**
2010-02-02-04:20*032*-000.4*000.0*00.0*00.0**
2010-02-02-02:01*034*-001.1*002.2*00.0*00.0**
2010-02-02-01:55*036*-001.2*000.1*00.1*00.1**
2010-02-02-01:38*037*-003.2*000.2*00.2*00.2**
2010-02-02-01:37*040*-000.1*000.0*00.0*00.0**
2010-02-02-01:35*040*-000.4*000.0*00.0*00.0**
2010-02-02-01:23*041*-002.2*000.1*00.1*00.1**
2010-02-01-23:50*043*-002.3*001.4*00.1*00.0**
2010-01-29-03:55*046*-002.4*091.4*00.0*00.0**
2010-01-24-05:49*060*-006.7*117.4*00.1*00.0**
2010-01-24-05:15*071*-004.3*000.5*00.5*00.1**
2010-01-23-04:15*075*-006.6*024.7*00.6*00.5**
2010-01-23-00:33*086*+018.5*003.6*00.2*00.2**
2010-01-22-21:59*044*-010.2*002.4*00.4*00.1**
2010-01-22-06:12*076*-000.8*015.6*00.0*00.0**
2010-01-22-04:54*100*+003.9*001.2*00.0*00.0**
2010-01-22-04:35*100*-000.5*000.2*00.0*00.0**
2010-01-22-02:35*100*+002.2*001.9*00.3*00.3**
Record 8/16: Battery manipulation (e.g. charging)
2010-01-23-04:15*1*36*27*00*09*2000-01-01-00:00*02**
2010-01-23-04:15*1*35*27*00*09*2000-01-01-00:00*02**
2010-01-23-02:39*1*34*27*00*09*2000-01-01-00:00*02**
2010-01-23-02:24*1*33*27*00*09*2000-01-01-00:00*02**
2010-01-22-06:12*1*32*27*00*09*2000-01-01-00:00*02**
Record 9/16: Battery aging
2018-10-17-22:07*053*077*071*051*08102*12.40*+23*02**
2018-10-03-21:22*053*077*069*050*08050*12.40*+24*02**
2018-09-20-08:48*053*075*070*049*07995*12.40*+21*02**
2018-09-06-01:23*053*077*079*062*07936*12.50*+26*02**
2018-08-21-22:06*053*075*080*066*07863*12.50*+31*02**
2018-08-07-21:31*053*076*077*067*07805*12.50*+38*02**
2018-07-24-08:50*053*076*081*068*07749*12.50*+31*02**
2018-07-10-07:07*053*082*076*062*07669*12.40*+29*02**
2018-06-27-02:20*053*076*080*063*07595*12.50*+26*02**
2018-03-26-09:41*053*078*072*038*07432*12.40*+09*02**
2018-03-05-08:28*053*073*056*018*07388*12.20*+05*02**
2018-01-20-16:21*053*072*081*047*07316*12.50*+11*02**
Record 10/16: Dynamic energy management
2010-01-29-03:55*1*001.0*1*003.3*00.08**
2010-01-23-00:33*1*001.0*1*002.5*00.06**
2010-01-22-21:59*1*001.0*1*000.1*00.02**
2010-01-22-00:48*1*000.1*0*000.0*00.01**
2010-01-22-00:06*1*001.0*1*000.6*00.03**
2010-08-27-22:03*1*0*0*00.21**
2000-01-01-00:00*0*0*0*00.00**
2010-01-29-03:55*2*004.3*00.08**
2010-01-23-00:33*2*003.4*00.06**
2010-01-22-21:59*2*001.1*00.02**
2010-01-22-00:48*2*000.1*00.01**
2010-01-22-00:06*2*001.6*00.03**
Record 11/16: Recuperation
2014-12-10-17:34*000*000*057*000*0249*071*00.1*00.6*090*076*0 90*077*02*00342*00379*00027*00739*01601**
2014-12-10-17:11*000*000*007*000*0008*064*00.0*00.0*090*076*0 90*076*02**
2014-12-08-15:05*000*000*000*000*0000*000*00.0*00.0*090*076*0 90*074*01**
2014-12-08-10:45*000*000*005*040*0063*047*00.0*01.1*090*074*0 91*076*01**
2014-12-08-08:46*000*000*022*000*0149*029*00.0*01.1*090*073*0 91*075*01**
2014-12-08-08:11*000*000*000*007*0014*008*00.0*00.4*090*072*0 90*073*01**
2014-12-08-07:49*000*000*001*009*0002*010*00.0*00.3*090*073*0 90*073*01**
2014-12-07-20:29*000*000*016*000*0052*017*00.0*00.8*095*076*0 96*079*01**
2014-12-07-19:15*000*000*022*000*0068*023*00.0*01.0*095*075*0 96*079*01**
2014-12-07-18:49*000*000*021*000*0090*023*00.0*01.2*095*075*0 96*079*01**
Record 12/16: Start-Stop
2000-01-01-00:00*0-0-0-0-0-0-0-0**
00000*00000*00000*00000*00000*00000*00000*00000**
2010-02-02-05:06*1*042*027*+23*04*-030*-21.11*11.7*0**
2010-02-02-05:05*1*042*027*+23*04*-030*-22.24*11.6*0**
2010-02-02-05:05*1*042*027*+23*04*-030*-11.82*11.7*0**
2010-02-02-04:53*1*044*027*+23*04*-030*-11.71*11.8*0**
2010-02-02-04:53*1*044*027*+23*04*-030*-13.04*11.7*0**
09218*00000*00000**
Record 13/16: Sporadic alternator faults
2014-07-08-16:52*1-0-1-0-1*000.0*00007**
2014-07-08-16:52*1-0-1-0-0*000.0**
2014-07-08-16:52*0-0-1-0-0*000.0**
2014-05-02-13:47*1-0-1-0-1*000.8**
2014-05-02-13:21*1-0-1-0-1*000.4**
Record 15/16: Local activ.
2010-07-18-13:32*05f*44*00*000*00*00*000*00*00**
2010-07-07-23:04*05f*43*00*000*00*00*000*00*00**
2010-02-03-17:12*05f*42*00*000*00*00*000*00*00**
2018-10-27-16:58*05f*41*00*000*00*00*000*00*00**
2018-10-27-16:51*05f*40*00*000*00*00*000*00*00**
2018-10-10-06:35*05f*39*00*000*00*00*000*00*00**
2010-03-17-07:54*05f*38*00*000*00*00*000*00*00**
2010-02-15-04:22*05f*37*00*000*00*00*000*00*00**
2017-12-10-16:25*05f*36*00*000*00*00*000*00*00**
2017-11-28-02:23*05f*35*00*000*00*00*000*00*00**
Record 16/16: Vehicle energy balance
192618**
08453*05019*01649*00174*00058**
14983*00150*00047*00014**
21842*18010*00283*00000**
02718*04335*03627*04012**
06964*05926*01802**
18513*00889*00218*00011**
05775*00047*00007**
00000*00000*00000**
00032*00000*00001**
00000*00000*00000*00000*00000*00000*00000*00000*00 000*00000**
VCDS Release 19.6.0: SRI Reset
Control Module Part Number: 8T0 920 983 D Labels: .8T0-920-xxx-17.clb
Component:KOMBIINSTR. H38 0258, Coding:8B1501000300D705020000
Operation: Please select an operation
Channel Description Unit Current val. New val.
02 Service Reminder Status 2 ---
40 Distance since Service km x100 82 ---
41 Time since Service Days 365 ---
42 Minimum Distance to Service km x100 150 ---
43 Maximum Distance to Service km x100 150 ---
44 Maximum Time to Service Days 365 ---
45 Oil Quality 1 ---
47 Soot Quantity DIST x100 17 ---
48 Thermal Load DIST x100 187 ---
49 Minimum Time to Service Days 365 ---
50 Basic Distance Value for Oil Change km x100 160 ---
51 Basic Time Value for Oil Change Days 0 ---
52 Basic Distance Value for Inspection km x100 160 ---
53 Distance since Inspection km x100 87 ---
54 Basic Time Value for Inspection Days 365 ---
55 Time since Inspection Days 395 ---
56 Day Counter Days 3239 ---
Address 19,8T0 907 468 AD,channel 1,adapted from,0,to,1,
Activating transport mode...Done.
Address 19,8T0 907 468 AD,channel 1,adapted from,1,to,0,
De-activating transport mode...Done.
www.Ross-Tech.com
6C
Revision: 76H22---
1 Fault Found:
U0101 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 39.0°C
Voltage: 11.811 V
Coding: 110D18
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0037
Hex Value: 0x3993
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:55
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0032
Hex Value: 0x0293
Hex Value: 0x00FF
Revision: 00002001
Coding: 0F0000
Coding: 48122000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Coding: 00FD11
Coding: 02532C
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Coding: 200002
Coding: 000016
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:56
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Freeze Frame:
Voltage: 11.80 V
Count: 66
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Coding: 0000002
Coding: 1000008
1 Fault Found:
U0101 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 39.0°C
Voltage: 11.811 V
Address 01: Engine
Revision: 76H22---
Date: 23.11.10
Flash Status
Misc.
Car Info
Engine code: CAUB
VCDS Info:
Address 01: Engine
Revision: 76H22---
Date: 23.11.10
Flash Status
Misc.
Car Info
Engine code: CAUB
VCDS Info:
1 Fault Found:
U0101 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 39.0°C
Voltage: 11.811 V
Address 01: Engine
Revision: 76H22---
Date: 23.11.10
Flash Status
Misc.
Car Info
Engine code: CAUB
VCDS Info:
6C
Revision: 76H22---
1 Fault Found:
U0101 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 04:50:03
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 23.0°C
Temperature: 32.0°C
Voltage: 11.811 V
Coding: 110D18
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:53
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0037
Hex Value: 0x3993
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:55
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0032
Hex Value: 0x0293
Hex Value: 0x00FF
Revision: 00002001
Coding: 0F0000
Coding: 48122000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Coding: 00FD11
Coding: 02532C
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:00
Coding: 200002
Coding: 000016
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:56
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 89
Mileage: 192618 km
Time Indication: 0
Date: 2010.02.02
Time: 01:59:52
Freeze Frame:
Voltage: 11.80 V
Count: 66
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Coding: 0000002
Coding: 1000008
History Data
09218*00000*00000**
192618**
06964*05926*01802**
05775*00047*00007**
00000*00000*00000**
00032*00000*00001**
WODT-Sanders
VAG-COM Discussion
06-15-2019 03:25 PM
Ocranius
A4 (B8 Platform) Discussion
17
08-18-2010 10:28 AM
BostonCactus
07-31-2002 07:32 AM
