Expansion tank blew up... Help
Old 12-12-2017, 08:31 PM
JoeIndy35's Avatar
Default Expansion tank blew up... Help
So my expansion tank blew up 2 weeks ago. Ordered a new one, installed it, filled with proper coolant. Let it run, it got to temp, re checked the level, it was topped off perfect. Now I have a new issue. When I'm driving it, around 15 min after it gets to temp, the coolant warning light comes on. Temp gauge reads perfect, pull cap off, level is still perfect. What could be going wrong? Do I maybe need to bleed the system? Maybe air in it? What's odd is I can shut it off, start it back and no light. However 15 min later it will come back on. Possible bad level sensor in the new tank?
Old 12-12-2017, 08:55 PM
JoeIndy35's Avatar
Oh, I'm using my older factory cap still. Not sure if that would cause an issue. No coolant leaks from it when it's running so assuming its fine
JoeIndy35
Q7 MK 1 Discussion
12-13-2017 04:18 AM
ptbo
09-20-2007 07:34 PM
Sergei
9
04-01-2003 09:38 PM
tankman86
03-28-2003 09:51 PM
thermonuclear
03-16-2002 03:22 PM
Quick Reply: Expansion tank blew up... Help
