Fuel injector pigtail replacement - B6 S4
Old 05-31-2017, 05:02 PM
GruvenS4's Avatar
Default Fuel injector pigtail replacement - B6 S4
When I was replacing the valve cover gaskets on my 2004 S4, I accidentally broke one of the connectors to my fuel injectors on the passenger bank. It gave me a misfire, and I tracked it to cylinder 2, and then found that to be the problem. As I removed the harness to get to it, I broke 2 other plugs, so I need to replace all 4. I bought some at Napa that they had listed for the car, but they are rectangular instead of oval shaped and will not fit.
I am having such a hard time finding replacement plugs/pigtails to buy. The part number on the plug is 06A973733 and 6289-0785, which doesn't yield much in the way of results. I imagine this is a commonly used injector and maybe I can use a universal plug if it matches exactly. I'm going to have to solder it in anyway.
Anyone else have this issue?
Attached Thumbnails Fuel injector pigtail replacement - B6 S4-img_0752.jpg   Fuel injector pigtail replacement - B6 S4-img_0751.jpg
Ballin'A4
1.8T Discussion
01-20-2009 11:15 AM
S-road
12-03-2007 06:16 PM
LarryF_in_Ca
02-27-2005 08:19 PM
stormchaser
02-23-2005 06:29 PM
JazzGuitarist
07-14-2003 12:47 AM
Quick Reply: Fuel injector pigtail replacement - B6 S4
